SMOG question:hydrocarbons in my car
HontegraGSI
09-05-2005, 08:28 PM
Hi everyone i did my smog two years ago and i just barely passed when it came to the category of hydrocarbons. The limit was 70 and my actual was 70! and now comes that time to smog, how can i reduce my numbers??? so far i got a new cat converter and i was thinking of getting a o2 sensor, i really dont wanna fail this time. any other areas i should check for for hydrocarbons??
Black92LudeSI
09-05-2005, 10:23 PM
I think you can buy something at pepboys, like emmisions passer or something. Its a bottle of something you pour in the gas tank. Its a possibility
HontegraGSI
09-05-2005, 10:29 PM
So hydrocarbons have to deal with gas?!?! thanks for the help. any other suggestions??
i_a_n112784
09-06-2005, 11:53 AM
Hydrocarbons ARE gas. Unburnt gas to be exact. Change the replaceable parts of the ignition system, distributor cap/rotor, and plugs. Make sure your wires are in good shape. Those will make small improvements. If you need a big change in numbers, you might want to consider changing the 02 sensor if it's old, or you don't know when it was done last. Just because it doesn't throw a code doesn't mean its working right.
And make sure the car is at normal operating temp before you go, don't go with a cold engine.
Greenblurr93
09-06-2005, 01:20 PM
a new cat will always help...
Smoghog
09-06-2005, 06:45 PM
If you have replaced the cat you are probably going to pass, But you can do damage to the new cat if your fuel mixture is not correct. I would throw an o2 at it just for piece of mind.
I ditto about sparkplugs and cap and rotor. Replace if not done and check your timing you could fail just because of timing.
I don't know what state you are in but CA. now tests for Nox (oxides of nitrogen) Another reason to put a new o2 in.
Good luck,
Smoghog
Good luck,
Smoghog
