Engine swap in a 1993 pontiac grand am
suds1215
09-05-2005, 01:05 AM
Do u think i can swap a v6 engine from a 1993 pontiac grand am into my 1993 pontiac grand am which has a v4?
GTP Dad
09-05-2005, 07:59 AM
You can swap a V6 into this model but you will need the computer and wiring harness to go with it. You will also need new motor mounts and possibly the transmission for the V6. You may run into clearance issues as well as having to build a custom exhaust. Could be quite expensive.
suds1215
09-05-2005, 12:17 PM
what if i was reciveing a 1993 pontiac grand am with the v6 and everyhitgn in it but it has too much body damage so thats why i want to swap engines?
GTP Dad
09-05-2005, 01:33 PM
Since you have everything available to you then go for it. There will be quite a bit of work to do this but if you don't mind the work then you should have no problems with the swap.
skibum1111
09-05-2005, 05:45 PM
You will need the engine harness, dash harness, ecm, instrument cluster, motor mounts, transmission, exhaust, shifter, air cleaner assembly, radiator, power steering pump, power steering lines, engine cradle, probably some things I have forgotten. Good luck, its a big job to do, make sure you don't cut anything on the donor car as you will probably need it.
truck150
09-08-2005, 08:27 AM
its 10 times easier to just pull the subframe(engine cradle) down then to try and pull just the motor.
