timing on 1991 honda accord
rfchil
09-04-2005, 12:12 AM
I am setting up from scratch an F22A1 engine in a 1991 Honda Accord.I need to know the complete procedure in getting the timing and everything set up.When I recieved the engine the camshaft and balance shaft belts were gone,idlers out of wack,,you know the story,,,the motor is ok ,, no bent valves etc.,,kind of a rebuild situation that lost interest.I have a Haynes book that shows lining up timing marks ,TDC etc. just for replacing the belts and stuff ,not really a from scratch procedure could someone help me out here I sure would appreciate it!
superbluecivicsi
09-04-2005, 12:12 PM
haynes covers the timing belt, camshafts, and ignition procedures. it also has the diagram and specs you need. reread it, follow there procedures and specs, and you will be fine.
