92 P.A. Relay Location (Fuel Pump)
Paul T
08-28-2005, 07:39 PM
Can anyone tell me where the feul pump relay is located on my 92 P.A. ?
I'm the guy that has been suffering with a stalling problem after vehicle is warmed up. I replaced the ignition module and coil towers this weekend and I get the same problem. Stalling after warm-up or unable to re-start after warmup. There is no spark from any coil. The coils are wired so that a common conductor is switched through the fuel pump relay. It is the only "common" electrical connection I can see on the schematic that if "opened" would cause all three of the coil towers to fail.
Thanks, Paul
Thanks, Paul
HotZ28
08-30-2005, 10:09 AM
It is located under the dash, passenger side. Here is what it looks like;
http://www2.propichosting.com/Images/421618027/0.jpg
