Coolant Leak
tag1240sr
08-28-2005, 03:43 AM
Need help!
I am having a major coolant leak right by my upper rad hose. My blazer is a 98 4x4 LS. I have replaced the water pump, upper and lower rad hoses, thermostat, and rad. I have flushed the system. I am now use prestone green. Leak seems to be on the Drivers side of the vehicle.
tag1240sr
08-28-2005, 10:59 PM
So I found it was my intake gasket and I have replaced it. Now my blazer wont start. I am getting spark, and fuel. blazer is turning over but won't start. while trying to start sometimes I will see smoke come up from the TB. Tried to reverse the timing and that just gets me a back file popping sound.
Need help. Have to use this vehicle for work.
aleekat
08-29-2005, 07:43 AM
Sounds like when you put everything back together, you missed something.
