88 bronco II not starting
kevro
08-26-2005, 06:00 PM
ok so ive got plenty of fuel, but when i check for spark off the coil wire the only time it sparks is when the person turning the key lets go, ill get two sparks as it is stopping cranking. during cranking no spark at all.
HELP?????
thanks,
confused and sitting still
cougarman
08-27-2005, 09:19 PM
Sounds like the ignition module (TFI module ) is toast. It's located on the side of the distributor.
kevro2000
08-29-2005, 02:13 AM
any way to check it? or go without it??
cougarman
08-29-2005, 10:11 PM
Pick up a Haynes Manual, not too expensive but tons of info inside.
I checked one I have for a different model Ford, and it explains in detail how to check the module and stator with a test light and a ohm meter.
TFI modules are not too expensive if you go aftermarket. I prefer Ford OEM parts, but aftermarket will work fine.
badasstour
10-15-2005, 09:18 PM
no it will not run without the tfi did it run like crap before it wouldnt start like sputtring jerking like that and the tfi is a bitch to change if you have the 2.9
