Axels for my b20
Sargento69
08-26-2005, 03:45 PM
i have b20b in my 90 crx. My axels are starting to make noises when i make a turn. My question is out of what car can i use the alxels from?? When i got the b20 it was in my friends 91 teg. Could it be that 91 teg axels fit my crx?? or am i assed out and have to go buy aftermarket b-series swap axels?? thanks for the help!!
civickiller
08-26-2005, 03:53 PM
what kind of tranny ? what kind of intermediate shaft ?
Sargento69
08-26-2005, 03:55 PM
Im Running A A1 Ls Cable Tranny
civickiller
08-26-2005, 04:20 PM
if you are using the same intermediate shaft that came with that tranny then 90-93 teg axles will work. i have the same tranny and i am using 90-93 axles on mine
Sargento69
08-26-2005, 04:31 PM
yes it is the intermeditae shaft that came with the tranny. so its 90-93 teg axels ok. hey man thanks alot for the help ok. one more question i am probably gonna upgrade the clutch and the flywheel. when i ask for the clutch and the flywheel is it the same thing 90-93 teg??
civickiller
08-26-2005, 04:51 PM
flywheel is the same for every year integra 90-01 so that doesnt matter and for the clutch its different between 90-91 and 92-93. so make sure you get one for the 90-91 integra
Sargento69
08-26-2005, 05:00 PM
oh ok then. thanks alot once again.
Sargento69
08-29-2005, 06:01 PM
one more thing i have been wanting to gt a cold air intake for my car. Im sure that the crx intake doesnt fit. So what car and year can i use on it??
Kunundrum
08-30-2005, 05:46 PM
intakes are all pretty similar, well for our car anyways, I have used the same intake on 4 different motors (D16a6, DOHC ZC, JDM B16 and B17a) so you should be fine... it also made a short stay on my DPFI Civic back in 98... as long as it's short ram, you should be fine.
Sargento69
08-31-2005, 11:16 AM
I kinda knew that short ram intakes would work on mostly all motors. But i am still wondering for the cold air intake
civickiller
08-31-2005, 03:35 PM
email aem, they might know because probably alot of people have asked them about it before
Sargento69
09-01-2005, 10:53 AM
ok tell me try that
