reverse light hook up
directory
08-25-2005, 10:35 PM
i want to install a set of auxillary reverse light on the lower bumper or on to a tow hitch.
is it possible to wire them into the existing factory reverse light power wire--this way when i put the vehicle in reverse, all (4) the lights come on.
should i use both the power and the ground on the factory reverse light, or just the power wire and ground the aftermarket lights to the body?
--B
--B
iskiuskiweski
08-26-2005, 07:23 AM
I would be reluctant to hook any high powered lights to the existing circuit, it is easy to overload. If it were me I would install a relay for new lights, and run a new fused wire from up front. Just my two cents.
directory
08-26-2005, 01:21 PM
would i tap off the reverse switch in the gear shift? would that be a good idea?
--B
--B
iskiuskiweski
08-26-2005, 01:32 PM
I wouldn't, most of time they don't give you any spare capacity. It may cause you problems.
Davejb
08-26-2005, 07:10 PM
What I would do is mount a relay at the rear of the truck, run a fused power wire from the battery to the relay (making very sure it's protected and won't get pinched), hook the relay trigger to the factory reverse light wire, and run the aux lights off of that.
iskiuskiweski
08-29-2005, 09:14 AM
That's it.
spishack
09-01-2005, 10:37 PM
I installed some auxillary back-up lights on my Rodeo by tapping into the back-up light lead wire in the rear light assembly. They are Kc lights product #517. Comes with a wiring harness and everything you need to make 'em work.
http://www.kchilites.com/store/2x6-Back-Up-Flood-LightsbrSystem-517-P1C26.aspx
directory
09-02-2005, 04:50 PM
outstanding, thank you all
directory
09-06-2005, 12:02 PM
what size relay would i use?
Davejb
09-06-2005, 04:01 PM
The standard at most auto supply stores I've found is 30 amp, more than enough.
