03 Silverado Warranty Question
Paul Gavaza
08-25-2005, 10:03 PM
I have an '03 Silverado 2wd with 25 K miles on it. I'm feeling what I believe is a warped brake rotor.
Are these things under warranty?
Paul G
jethro_3
08-25-2005, 10:20 PM
More than likely they are going to say, "Normal wear and tear." Unless you can show three straight and true and one way out there, you might have a case... Good Luck.
Ape0r
08-26-2005, 06:09 AM
Brakes are typically covered 2yrs/24k. Take it to the dealer and see what they'll do for you.
SWEATBREAD
08-26-2005, 09:19 PM
Gm Warrenty Policy On Brake Rotors Is That As Long As The Brake Pads Are Not Worn Down And The Vehicle Is Still With In The 3 Year 36k Mile Warrenty And The Cause Is A Warped Brake Rotor, You May Have The Brake Rotors Machined Once And Once Only Under Warrenty.
