Ka24e auto to manual swap
Waltz
08-24-2005, 12:32 PM
Hey , im changing my auto tranny to a manuel one next week , and i'd like pointers to some of the problem's i might encounter if any.
Got all the needed parts (clutch cylinders , drive shaft , sensors , flywheel , pressure plate,pedal's )
also tell me if im missing stuff in here.
wotandsdwys
09-12-2005, 02:56 PM
I think the automatic ECU will throw a code with the manny trannie, but should run.
I think it also gets rid of your top speed limiter too.
other parts you either need, or didn't list that you have: Clutch fork, NEW Throwout Bearing, NEW pilot bushing, NEW clutch slave cylinder (if the old one has been out of the car for a while, it could be dried up and un-usable), clutch lines, a nice big jug of DOT3, hopefully you have the clutch friction disc to go along with the pressure plate!!
also, just a reminder, don't let the input shaft carry the weight of the whole transmission while you're putting it up, it can be a pain and get pretty heavy, so back it off the engine and let the tranny sit on the jacks.
Waltz
09-13-2005, 08:22 AM
hey thks for the reply didnt check it in time unfortunatly , but thats all stuff i knew) (i finished my mecanics course with high honors last may ^^ )
Ho and the clutch kit had just been put on the tranny before i bought it , so i did'nt have to change anything.
And you wanna hear something weird... My auto tranny did NOT have a top speed limiter on it 0_o , i got car up to 215 km/h , but just to be sure , im not pluggin in the 5th speed sensor on the manual one.
And another weird thing , i didnt plug the neutral sensor (says in the manual that if it is not plugged in the engine could stall because the ecu cuts injection in decel ) but everything runs just fine weird hun ^^
anyhow , thks again
