Clarification on Torsion Bar Mounts 96
dwitczak
08-24-2005, 07:01 AM
I read alot of threads and the dealer. With a 96 blazer 4x4 do the front or rear torsion bar mounts ever go bad? I see there are alot of discussion about 95 and older with the mounts going bad. I need to replace the lower and upper control arm bushings and in doing so I need to remove the torsion bars. If there is anything the can wear out with the torsion bar I would like to replace it at this time.
What I am looking for is a simple clarification with the what is different between the the older and new torsion bar mounts.
BlazerLT
08-24-2005, 10:01 AM
The old ones were sold torsion bar mounts like this.
http://www.sytyarchives.com/howto/viewarticle.php?article_name=torsion_bar_mounts.ph p&dir=suspension
The new ones are different and are more like hangers.
dwitczak
08-24-2005, 01:30 PM
Thanks LT, does that mean the newer ones do not typically wear out. If I have to remove the torsion bar to do the control arm bushings. should I replace anything on the torsion bar?
BlazerLT
08-24-2005, 02:25 PM
not as much as before.
Inspect to see if the torsion bar mounts are worn or rubbing the inner frame.
dwitczak
08-27-2005, 09:05 PM
On my 96 blazer. Is there a way to replace the lower control arm bushings without removing the torsion bar?
BlazerLT
08-29-2005, 12:59 PM
We are not talking about those kinds of mounts.
Please post your own thread.
