2.8 timing
Jcrane88
08-23-2005, 03:52 PM
i got my car running but the timing aint right, we had the timing light out the other day but im not sure what the timing is supposed to be at
any help would be appreciated
John
wrightz28
08-23-2005, 04:13 PM
s/b on the decal on your hood.
Jcrane88
08-23-2005, 04:21 PM
decal is gone........i think its at 12 degrees right now
wrightz28
08-23-2005, 04:28 PM
oh ok, yeah. s.b 0-4? I know the 8's are at 0*. a;; I can say is make sure you have teh ecm ref. wire off and set it by ear, 12 may be a bit much?
Jcrane88
08-23-2005, 04:32 PM
there is no computer hooked up to this car..........lol the only thing that controls this car is my foot
supervisor1886
08-23-2005, 10:28 PM
I would say 6 to 8 on a carbed car.
orion_X_100
08-24-2005, 11:46 PM
i set mine as close to 10(what the decal on hood says) as i could get it, what would a 6-8 do performance wise?
supervisor1886
08-25-2005, 01:00 PM
It depends on the condition of the engine too. And some
prefer to do it with a vacuum gage. I would say go really advanced and then when you hear ping going under heavy load back it up a couple degrese. But 10 should be ok to. Just play with it so it has more power better drivability and doesnt bog. First make sure yor carb adj is good,no vacuum leacks,etc.
DrPlatinuim
08-27-2005, 11:20 PM
I had a prob with my 87 2.8 camaro's timing.. it is suppose to be set to 10 degrees.. But also dont forget to unplug the timing sensor when doing so.
DrPlatinuim
08-27-2005, 11:24 PM
I had a prob with my 87 2.8 camaro's timing.. it is suppose to be set to 10 degrees.. But also dont forget to unplug the timing sensor(im not sure if thats what it is called but it is located by the firewall. If standing in front of the car looking at the engine.. it will be on the left side. Mine was inside a black heat-protected tubing.) when doing so.
