1996 '88 a/c switch problem?
hotrodihc
08-19-2005, 10:30 AM
The a/c system is fully charged up and working but no cool air is blowing from the vents. The temp control works when I turn it to hot, but it blows warmish air when turned to cold. Is this a temp switch problem or is there some other cause? No vaccum leaks and everything blows through the right vents.
Hot in TX
Hot in TX
atv087
08-19-2005, 11:06 AM
so your saying your ac is blowing out the right vents and not the left vents or its just blowing out warmish air all the time on ac if its doing that then id check the blend door if its blowing out of just the right vents you may have a actuator problem. Let me know if your ac clutch is kicking on when you turn the ac on
atv087
08-19-2005, 11:07 AM
if its fully charged it should kick on and then id suspect a blend door problem which you could probaly fix by replacing the climate control on the dash
hotrodihc
08-19-2005, 11:36 AM
not the "right" vents, the correct vents. Dang the english language!
a/c is fully functional, just not blowing cold air from the vents. I assumed a blend door or the temp switch and wasn't sure if anyone else had run into this problem before. thanks!
