teg short shifter differences??
brookz
05-04-2002, 11:11 AM
hey everybody. this might be a stupid question, but does anyone know if there is a difference in short shifters for years 94-97 and 98-00 for the integra? i thought they were the same for 94 through 00/01.
is there also a difference in them for the type of trans? LS/GS/RS/GSR? i'm looking for a GSR shifter and the one that I have now is not as wide at the base as the OEM one (where it bolts into the shift rod). i'm trying to find a new one, but the ads say - 94-00 all or it's for the LS/GS/RS.
RedRocketGSR
05-05-2002, 02:41 AM
Yea the base part on any short shifter will never be the same as OEM. It's shorter so i suggest you put some metal washers in there and jam 2 rubber washers in there(one on each side) so the metal washers dont vibrate and make an annoying sound. I believe all the short shifters are the same but the GSR has a shorter throw stock than the LS and also closer gears. Good luck to ya though.
M-type
05-06-2002, 03:57 AM
also invest in some stiffer, polyurthane bushings, cause you might miss the shits with the shorter shifter
brookz
05-10-2002, 10:41 AM
thanks. i already have the bushings installed and just ordered a new short shifter anyway. thanks.
