70 4 door
dannodragoon
08-16-2005, 05:53 PM
i've got a 4 door and was wondering is there any way to gain access to the trunk from the inside of the car? somebody tried to break into the trunk and the lock is all screwed up.
thanks
thanks
ctesla
08-16-2005, 09:08 PM
best thing to do is drill the lock out, or punch it out,
use a screwdriver to open, until you buy an aftermarket lock/key/tumbler set and re-install
(or take the lock set first to a locksmith, so instead of another key, they can key to the door one.)
the trunk metal is sound, even if you bend a little by the lock, you can use a pair of needle nose to bend it back, and the new lock will have a lip on it, to assist in covering any minor marring.
...that said, you could take a broom handle, drill a small hole in the end, take a cheap screwdriver, cut the handle off, ream the screwdriver into the hole in the broom stick, take the back seat out, and with the broom and a flash light, you'll be able to pop the trunk from inside.
good luck,
which ever way you go.
chris
nrt racing
good luck,
chris
nrt racing
Tomsriv
08-16-2005, 09:58 PM
Use it as a parts car for a decent 2 door.
