Clicking noise won't turn over
Wolfgriffon
08-15-2005, 10:17 PM
I have a 96 Ram Sport 5.9 Magnum. Truck never had a problem starting till today. Just as it was about to turn over, it started clicking. The sound was coming from the starter, but I replaced it and it still continues to click without starting. :banghead: What else could be causing this problem? Could it be something else I haven't checked?
Please help...I am going :screwy:
Thanks
Thanks
BleedDodge
08-15-2005, 10:38 PM
Bad battery connection can do that.
Maybe the motor has seized.
Wolfgriffon
08-15-2005, 10:50 PM
Wouldn't the truck overheat or check fluids or something like that happen first? It drove and started fine all day...till it did this...after I stopped for beer at the end of the day.
Checked battery connection first...it's good.
fanworks
08-16-2005, 01:59 AM
Have you recharged the battery since the starter replacement? Usually a low battery or failing solenoid will cause the to make a clicking sound.
Wolfgriffon
08-16-2005, 07:51 AM
Thanks but the battery is brand new.
could the power relay harness cause this?
jrmcx
08-18-2005, 01:38 PM
Recheck / retighten the connections at battery and starter. Put a voltmeter on the battery.
Wolfgriffon
08-18-2005, 02:05 PM
Thank you all for your help!
After checking the battery once again, it seems that I bought one that was defective. It starts fine now after getting another battery!
