tach on 96 geo prizm
jawberger
08-14-2005, 12:24 PM
Hi
i've been trying to put a tachameter on my 96 geo prizm and i can't figure out where i'm suppose to connect all the wires the the directions say is look in my manual and all my manual says is that a tach is an option you can get on my prizm... so if anyone could explain how to do this i would be very appriciative of your help
thanks!
chadi
08-15-2005, 02:32 PM
ok....so you have a tach...right?...if you do...do as the directions say...red to 12v power source...black to chassis ground....white to the gauge light fuse...(or you can connect it to any accessory power wire) and the green wire goes to the negative line out of the distibutor...it shold be the black one with the stipe...the stripe should e orage....
go get yourself a haynes repair manual....so you can know where everything is....
and before you post another question....look to see if it was alreasy asked....
peIce...
jawberger
08-15-2005, 03:50 PM
well i saw the 94 one but that one had a distrubator but the 96 is when they started making it some other way according to some article i read
thanks
