Scan Code Reader for 95 Aurora
zengel442
08-11-2005, 03:13 PM
I would like to purchase a code reader for a 95 and would like to know which code reader is compatible with that vehicle. The OBDll's are usually for 96 and above. The code reader that AutoZone uses will not work with my 95. Does anyone know which scanner will work with the 95's? The jumper technique will also not work correctly as I don't have the proper terminals. i.e. A & B.. Thankx in advance.. Frank
tedcopeland
08-17-2005, 10:30 PM
Unless they have come up with something recently, the only people who would have a code reader is the dealer. The '95's have a mongrel set-up in that regard something to do with OBD sensors and OBD Two connector. I believe the scan tool is a Tech One. My Snap On scanner won't work. Neither does the OTC. Call a dealer and ask to spek to the service manager. He MIGHT be able to explain it.
tedcopeland
08-17-2005, 10:31 PM
Unless they have come up with something recently, the only people who would have a code reader is the dealer. The '95's have a mongrel set-up in that regard, something to do with OBD One sensors and OBD Two connector. I believe the scan tool is called a Tech One. My Snap On scanner won't work. Neither does the OTC. Call a dealer and ask to speak to the service manager. He MIGHT be able to explain it.
