Intrigue ABS Prematurely Engaging??
Iggier
08-07-2005, 09:24 AM
My very low mileage (~17K) 2001 Intrigue recently started exhibiting the following:
Applying light brake pressure at speeds of 50 mph and greater on a straight road, as well as at 30 mph on corners, curves, downhill ramps and driveways results in a minor, but noticeable pulsating sensation emanating from the brake pedal. The pulsating can also be mildly felt within the vehicle, although I can't really describe it - a mininal, but steady vibration that seems to come from the center front of the car.
I had a friend drive it, without giving any clues of the problem, and he concluded the same "feel." From the passenger seat, I can even hear the rumble.
We considered that a rotor is out of round. However, the rumble/vibration is uniform and not associated with a particular tire or location. Brake pads are in excellent shape, so I'm presuming there's something faulty with the ABS.
Any ideas?
GTP Dad
08-07-2005, 12:21 PM
Do you actually hear the ABS engage? You should hear a chattering if it actually engages not just a pulsation. I would lean more toward a slightly warped rotor or an axle shaft than the ABS based on your description. If something was wrong with the ABS itself you should have an ABS light.
