2004 Z71 keyless remotes 1 and 2
christopherdavis
08-04-2005, 04:08 PM
Thank you to posters elsewhere on this forum, with your posts I was able to program a replacement keyless entry fob, and reprogram one of the original two fobs. In short:
turn key on and off
hold down door unlock button on door
turn key on and off twice more
release door unlock on door
hold down lock and unlock buttons on the fob simultaneously for 10-15 seconds
door locks cycle when fob is programmed
repeat holding down lock and unlock buttons on each remaining fob
turn ignition on to exit programming mode
check that each fob locks and unlocks the car
Now...
My remaining problem is:
My original fobs were labeled 1 and 2, and caused the seats, mirrors and radio to move to presets 1 or 2 depending upon which fob was used to unlock the car
Now that I have successfully programmed my replacement fob, and reprogrammed the original fob, I seem to have lost the function of moving to the driver 1 and driver 2 presets upon using the different fobs
Does anyone know how to redifferentiate the fobs to the car so that the function of moving the seats mirrors etc is restored?
If you do I will be eternally grateful, and it will restore domestic bliss on the home front as it is my and my wife's settings that are programmed into presets 1 and 2.
Regards, Chris.
