1995 Monte Z34
JJJ83
08-04-2005, 01:32 PM
My Monte has a severe stuttering problem when driving down the highway. It also runs really rough and doesnt have much acceleration. Also when the motor hesitates, the radio turns on and off and the speedometer and the rest of the electronics go nuts. It came back with an EGR code and I replaced the EGR valve and that didnt do it. Alternator and battery are good.
montecarlossfan
08-07-2005, 08:39 PM
check all of your grounds, its possible your neg cable is shot or not grounding properly...
montez34
08-16-2005, 12:32 AM
either that or your sensors are bad.
tazz311311
08-17-2005, 12:35 PM
i had the same problem with my 95 monte. it was the alternator. it had a hard time going from low rpms and headlights and radio would cut off. are you sure its not the alternator?
corning_d3
08-31-2005, 02:23 AM
I agree. Sounds like either a ground or alternator problem. Remember ground prob's can be hell on bearings...
