dodge ramcharger losing bat. power when hot
coleco
08-03-2005, 08:45 PM
I have a 1986 Dodge Ramcharger. When I first start in the morning it starts just fine, but After a few times driving during the day it just seems to get weaker and weaker. I have replaced the batteryt several times and just replaced the alternator. It ran great for the first couple of days, but just last night it was very slow cranking up. The last owner said that when he had it the battery would sometimes boil and then would be useless. It has a 360 that was rebuilt a few years ago. If anyone has any idea what the problem could be, all help will be appreciated. PS how long should a truck of this size be able to run off the battery alone? Because I have a feeling that the alternator is doing nothing.
flewthecoupe
08-03-2005, 09:25 PM
First off, this is the tbird forum. But no worries, we can try to answer. How long a vehicle will run on a fully charged battery without alternator power depends on many things. If all the accessories are shut off, radio, heater or a/c, no headlights, etc. you should be able to run for an hour or two with no problem. If there are several times that you have to shut the truck off and start it again will greatly shorten that time. Does the truck have an internal or external voltage regulator? If it is external, replacing the alternator will do nothing for fixing your problem. If your connections are not clean, or the cables are corroded inside the insulation, this could cause your problem. Just some ideas to start with. Good luck.
gcline
08-04-2005, 04:29 PM
I had a volare for several years. This is deffinately a voltage regulator problem. Its the little orange box on the firewall, but they might have changed where its located/looks like. If you look under the hood, and see that orange box with wires going to it, then thats it.
Jim Adams
08-04-2005, 09:57 PM
Give this a try,,does it always start ok when its cold and then as the motor gets hotter it cranks slower? And do you have to jump it or charge the battery?Try and see if you have good headlights with the heater blower on high after truck gets hot and the engine is off. If so then your problem may be in your starter ,,you have bad bushings in the starter causing the winding or armeture in the starter to start shorting after it heats up and the windings get hot,,called starter dragging,,, not sure but give that a try.
dlaughman@hotmail.
01-31-2006, 09:42 AM
I have a 73 Powerwagon 4X4 and it did the same thing what was happening was it had a bad ground I ran a ground wire from the voltage regulater toy the battery and it worked it would charge again it worked for me it might work for you
