Monitor Install Help
dna59
08-03-2005, 06:16 PM
I just installed my monitor in my eclipse but i get engine noise in the audio. I've tried everything i could possibly think of and it's still there, what 've noticed is that when i have on everything and i plug out the video cable for the monitor the noise goes away. At first i thought this was because it was next to the power wire which was a mistake i made so i put it on the opposite side of the vehicle and it's still there. The only two things i could think of is that maybe the video plug isn't good quality or maybe the cig. light plug is causing it. would cutting off the cig. plug wire and rewiring it fix the problem or no? I just hooked up a 12volt auxilary source under the dash and plugged the monitor's cig lighter plug in it. Could it be the cig lighter plug isn't grounding it good or something.
4g63gst20
08-03-2005, 07:52 PM
i'd say your ground conection is too poor, check the ground in all your stuff, cd player,amps, etc,
dna59
08-03-2005, 07:56 PM
i re grounded everything
cficare68
08-03-2005, 08:06 PM
Ok so when you regrounded it did you still us the cig plug into hook it up
dna59
08-04-2005, 07:16 AM
no i'm using the cig plug for the monitor but i re grounded the cd player and also the dvd player. so could it be the cig plug causing it or the video cable or somehting else.
david-b
08-04-2005, 02:44 PM
Use some high-grade audio/video cables.
