e320 wont start NEED HELP!!!!!
bimmerguy714
08-03-2005, 02:00 PM
I have a 2001 e320 wagon and all of a sudden it wont start. It had been sitting for two days, started fine, i drove it around for a while and when i came home i tried to start it again and it wouldnt start. It wont even turn over. I charged the battery and all i hear is a tick when i turn the key. Any ideas on what this could be? Fuel pump maybe? HELP PLEASE!!!!
talonlover
08-03-2005, 06:31 PM
Low or dead battery, starter or solinoid...I would check those first.
blindside.AMG
08-04-2005, 09:04 PM
Most likely a dead battery. If the fuel pump were bad it would crank but would not start.
eviltwin22
09-15-2005, 12:48 PM
I had the same problem..they told me it was a transmision control module...keeps the car form startiing if the tarnsmission isn't in par or neutral...I knew mine was problematic because the transmission wouldn't shift smoothly when I tried starting it in park rather than neutral.
johncar
12-03-2005, 01:17 AM
This could be the alternator is dead. The battery is drain out without getting charged from the alternator. This is why you run a while, then you could not start anymore.
