Squeeky rattle when clutch is engaging
98R/TDailyDriver
08-03-2005, 08:31 AM
I get this high pitched rattle noise at low RPM or when I'm going through a parking garage with my windows down. Can't hear it with the windows up. -Car sounds like a piece of shit
I figure it happens when the motor is moving on the motor mounts. I siliconed and or lubed everything I could see. Is there something I missed?
veedubmechanic
08-04-2005, 08:55 PM
sounds like a throw out bearing making noise.
98R/TDailyDriver
08-05-2005, 06:37 AM
Damn, I hate your responses because your probably right :banghead:
How long can I live with it before my clutch binds up. I assume it will eventually make a shitty noise when I engage the clutch...
98R/TDailyDriver
08-08-2005, 08:14 AM
Update: Doesn't happen when the clutch is pushed in -happens in gear in 1 & 2 only under 1800 RPMs
A rattly squeek -not a constant squeek.
veedubmechanic
08-08-2005, 09:31 PM
Check your engine mounts and transmission mounts. and other lower suspension components ( sway bar end links and sway bar bushings)
