draining my TH350
74NovaNick
08-03-2005, 08:04 AM
I'm havin a lil trouble. I'm trying to drain my tranny (engine replacement) and can't find the plug. Are the plugs only on the 400's? Do I have to loosen the pan? I slid the tranny mount back toward the rear end and still cannot find that damn plug!! Please help. Thanks.
- Nick
- Nick
74NovaNick
08-03-2005, 10:00 AM
got it figured out. thanks anyway
AlmostStock
08-04-2005, 02:05 PM
Do yourself a favor and install a drain plug while you have the pan off. You'll thank yourself next time you want to change the fluid or drop the pan.
bobss396
08-23-2005, 11:31 AM
The idea behind the no-plug pan is to force the mechanics to drop the pan in order to change the fluid. May as well change the filter while you're there too.
AlmostStock
08-23-2005, 11:37 AM
That may be but even if you are dropping the pan having a plug makes for a much neater job. Plus you can change your fluid more often without spending all the extra time of moving the crossmenber and removing the pan. I like to change the fluid every year. The filter maybe every 2-3 years.
bobss396
08-24-2005, 10:53 AM
Changing the fluid and NOT changing the filter is like taking a shower and putting on dirty underwear right after.
AlmostStock
08-24-2005, 03:16 PM
Not if your still changing the filter at the recommended intervals or sooner. Think of it this way; you change your fluid and filter at 40,000 miles. I change my fluid every 10,000 and the filter at 40,000. Which tranny do you think has cleaner, fresher fluid?
I have never seen a filter that was clogged, and never had an auto trans failure in over 20 years.
