no start
sharc
07-27-2005, 11:35 PM
i have a 97 2.2 that will not start i have fuel pressure, spark, and good compression on all cyl. but it will not start. going bald pulling hair out is there a sensor that im missing or ????? also i replaced the crankshaft sensor but i still have spark and fuel but does not attempt to start ???????? any help would greatly be appreciated thank you
drdd
07-31-2005, 09:53 AM
have you:
checked the battery charge (should be 12.5 or higher with engine off)
check the starter and solenoid for loose connections or melted stuff
What is your fuel pressure? do you hear the fuel pump prime when you first attempt to start?
