Plug Gap UNDER HIGH BOOST!!!
Stealth-Twinturbo
07-27-2005, 11:06 PM
I have my plugs gapped at .036 i plan on going to lager turbos running about 22 psi with FULL AEM EMS!! I think i should gap my plugs to .028 ? I will be running high boost and i don't want spark blow. What does everybody think.
Hotshot8792
07-27-2005, 11:19 PM
.028 is not a bad gap for that kind of boost. If your like me and can regapp your plugs in a matter of minutes, i'd go down to 0.032 first and see if i can get away with it first, cause remember, the larger the gap you get without blow out, the more power you'll be making. Now, if it takes you a little bit longer to pull the plugs, then just go ahead and to 0.028 and be done with it. Its hard to tell you exactly where to begin because every car is different.
Stealth-Twinturbo
07-28-2005, 12:11 PM
How the hell do you regap your plugs so fast?
Hotshot8792
07-28-2005, 05:01 PM
well, between the fact that i dont have any unecessary parts or brackets attatched to the intake manifold, and i've removed it 50 bazillion times, it takes me like 5 minutes to pull mine off. Then all i have to do is pull out the front 3, regap them, then pull out the back 3, regap them, put the intake manifold back on and i'm done
