Cooling help needed!
floaterboy
07-27-2005, 07:11 PM
I would like to install an electric fan in my '64 ChevyII. It has only a bit more than 3'' between the radiator and the water pump. Any ideas?
Floaterboy
Fyter87
07-28-2005, 04:06 AM
You have a Inline 6 huh? Why do you want to put in a Electric Fan? Theres not really a point enless you have a Small Block or Big Block or your running a transmission cooler or Oil cooler.
floaterboy
08-02-2005, 04:01 PM
355/370 hp, trans cooler etc.
nova68
08-02-2005, 06:16 PM
have you looked on jegs for like a low profile fan
bobss396
08-22-2005, 11:49 AM
I'd look into making sure you have a thick (4 row core) enough radiator, they're reasonable enough as new units, first. Also make sure you have a shroud which is easily good for 20 degrees. If you have a clutch fan, make sure it works, a new clutch unit is about $45.
Bob
Fyter87
08-23-2005, 01:20 AM
I dont know why I thought you had a Inline 6, that was weird, but I heard the closer the fan to the radiator the better.
floaterboy
08-28-2005, 08:52 AM
A flexalite black magic 150 did the trick.
wackypappy
08-28-2005, 08:11 PM
me know help on that fan stuff..you might join the nova list...lots of help with questions like that and lots of nice folks....thend.
