90 Firebird Help
trackwhore
07-27-2005, 07:03 PM
Hey hows it goin? I've got a base model 6 cylinder Firebird. Its an automatic. I've recently replaced the alternator, starter, and the idle air control valve. Basically stuff has just been goin on me and I keep replacing everything. The symptoms its showing now is : the car takes a while to start up, and then it revs weird and dies. If I hit the throttle, it dies.
My guess is that its the distributor or cap/rotor. My friend said there might be play in the shaft of the distributor and would mess things up. Other than that, I have no clue. Any help/suggestions would be highly appreciated. Thanks alot - dave
jason-1995fbody
07-27-2005, 09:14 PM
fuel\ fuel pressure could cause this or mass air flow sensor mabey tps but not likely check it any way
also dose the ses light come on while its running
