93 maxima engine problems. please help!
96blkcamss
07-25-2005, 06:36 PM
i have a 93 maxima. whatr happend was one day the low fuel light went on. i tried to start it and would not turn over at all. thought maybe it was comp-letely oput of gas. went to get 5 gallons and tried it again, nothing. pushed the gas and it finnaly started to try to fire then it did. went for about a week and a half and now it is running real rough at low speeds. feels like it has lost a lof of power. thinking it was the fuel injectors is my thought right? also if you think that that is right how do i get them out to check them? any help would be grately appreacited.
thank you,
brian
thank you,
brian
Nahkapohjola
07-26-2005, 02:31 AM
...would not turn over at all. thought maybe it was comp-letely oput of gas. went to get 5 gallons and tried it again, nothing. pushed the gas and it finnaly started to try to fire then it did. ...
- Highly unlikely six injectors die simultaneously. More like fuel pump problem.
- current problem could be also pump - or ign, some sensor.
No car runs without tuneup, check out:
http://www.cardomain.com/ride/748507/1
