sometimes it starts sometimes it won't
cosipper
07-25-2005, 11:43 AM
thats my problem. replaced all my relays and plug wires and stuff like that, but i still have this problem. its a 1991 PA and other than this it is in great shape. any ideas on what this might be?? thanks in advance.
matt
matt
cosipper
07-25-2005, 11:47 AM
can someone post a list of the relays and which one is which. the sticker on mine is gone and i'm not sure which relay is for what. thanks again.
matt
matt
cosipper
07-25-2005, 03:33 PM
well from what i've read in other threads i need to start looking at sensors now. which one should i start with and where is it. i found 2, one one the left side of the motor behind the middle pully and another one on the exhaust manifold(i think this is the oxygen sensor) what is the other? i know this has got to be something simple the car runs to good when it will start to be something hard to fix.
HotZ28
07-25-2005, 07:13 PM
:crying:
Check the fuel pressure & get a code scan. You may have somthing simple, like a bad key resistor or ignition switch resistor interpter. Check for stored codes, that will help diagnose the problem. It can get expensive throwing parts at it!! :banghead:
