need help bad
CAPRICE LIFE
07-24-2005, 10:28 PM
i have a 94 bonneville and the fan doesnt come on ne more.could it be the relay or the cooling fan sensor if my car has one. also where will the fan relay and coolong fan sensor be located. i need help ASAP
GTP Dad
07-25-2005, 10:26 AM
Test the fans using a power source to the wires in the connector. If the fans are good then the problem is in either the relay, located in the power control center (black box) under the hood. The temp sensor should be located somewhere on th radiator usually under the radiator cap.
CAPRICE LIFE
07-25-2005, 09:58 PM
i located the relays but which one exactly is it???there r about 6 relays that i c thats under the big fuses on the firewall...it would really help if i can get a pinpoint idea of which one it is...example:is it the 1st,2nd3rd,and so from the drivers side.thanks a bunch
DrJay
07-29-2005, 09:47 PM
IIRC if you're looking at the row of relays under the fuses the one farthest right is the low speed relay and the one to the left of it is the high speed. Should also check the fuse if you haven't already. The fuse covers should be labeled so it'll be easy to find.
