headlight issue
JustinCredible10
07-22-2005, 07:43 PM
What's up folks? Does anyone know if it's safe to put low-beam headlights into the high-beam socket? My low-beams only work if I pull the "light switch bar" toward me (as if I'm going to turn on the high beams) a small amount. For a quick fix I was thinking about switching the bulbs since I rarely use high-beams anyway. What do you guys think? Thanks.
Justin
Justin
Cavalier2000
07-24-2005, 06:09 PM
did headlights become expensive?
JustinCredible10
07-24-2005, 09:06 PM
What does that even mean?
Cavalier2000
07-25-2005, 05:04 PM
it means why don't u spend $5 for new low beams.
JustinCredible10
07-26-2005, 12:05 AM
Because the bulbs are fine. Like I said, when I pull the bar back, the low beams come on. It's not a bulb problem. It's an electrical problem within the steering column that I don't have time to fix right now. That's why I'm asking about a quick fix.
SlyBry
07-26-2005, 09:32 AM
I'm not sure about safety, but I'm pretty sure that the low beam and high beam/DRL sockets were different on my '97.
JustinCredible10
07-26-2005, 10:08 AM
I just hope there's not too much voltage going through the high beam socket that's gonna fry my low beam bulbs. That's the only thing I'm worried about.
Tookie
07-28-2005, 07:09 AM
You shouldn't have a problem with the volt/amp specs. The pwr supply system to the lights will (should) only supply the current the bulbs require, and I expect that should also remain stable at 12V+-.
Now there may be a problem with the connectors design; for as you know the bulbs catch pins are different for twin and single filament bulbs, in whih case some wiring mod may be the answer.
JustinCredible10
07-28-2005, 09:55 AM
Thanks for the reassurance Tookie. I'll take a look at the connectors' designs and see what I can do. Something I just thought of though...aren't the high beams angled differently, if so, will it still seem like I have my high beams on? I'm trying not to blind everyone else on the road. Thanks again.
Tookie
07-29-2005, 07:23 PM
I would expect them to be config'd for hi-beam operation. This could cause a problem with regards to beam coverage and affect oncoming drivers. There is one option, somewhat (tacky??) but creative none the less. Remember those half-moon headlight covers? Well you could use some aluminium duct tape to ensure most of the light stays down in the low beam region. Done right, it might even look uniquely original!!
For a temp mod till repair, it'll do.
Got a digital cam? Like to see the results.
