Interior questions about 99'
ryank771
07-20-2005, 01:45 PM
I have a 99' with Bronze Mist paint and tan leather interior. My problem --- the drivers seat is in great condition (thanks to Ziebart), but it's discolored due to oils, and dirt, etc. I noticed if I get a towl moist and scrub one tiny area for a couple minutes, it will come a lot cleaner but would take hours to do it. Does anyone have any good suggestions or materials to get the leather clean without damaging it?
Next question --- the rear deck inside the car rattles BAD when my bass is on. I can't find out where it's loose either --- anyone else experiance this and find a solution?
Thanks for any suggestions...
--ryank771
--ryank771
AbRaKaDaVa
08-04-2005, 12:06 PM
That rear deck is a motherfucker...Most likely your rattles are coming from the 3rd brake light. It is a loose component to begin with and couple that with the up and down motion that the bass will create and you have it smacking into the rear window.
Put weatherstripping on all of the plastic that is exposed to the rear window and sound dampen the rear deck while you're at it. Also remove all of the plastic panels to allow more sound into the cabin, and if you have a decent frontstage go ahead and pull those pile of sh*t 6x9's as well.
You might want to try using and adhesive to make the brake light more rigidly attached to the rear deck vanity cover as well but i've had very limited success trying to do that...
Hope that helps.
Hope that helps.
