Clutch Problem
msjalexbay
07-19-2005, 05:19 PM
I have a 98 Sahara with about 68K miles. Last night, the clutch worked fine. As I was leaving this morning, I heard a grinding noise when I push the clutch in. I cannot go into any gear at all. The engine turns over fine. There are no apparent leaks. A co-worker checked the reservoir, and he said the fluid level looks fine. My boyfriend is away. I hesitate to take it to a mechanic without first having an idea of what is going on. Does anyone have any insight on my problem? Help!!! Any feedback will be greatly appreciated!!! Thanks!
fredjacksonsan
07-20-2005, 11:17 AM
I'd go to the dealer right away; you're probably still good under the 7/70 powertrain warranty. If so, they will fix it for free. From your description it sounds like some work needs to be done.
