Question about SR20DET
MOMOG20
04-25-2002, 07:27 PM
is anyone put GTi-R engine on their G's?
if so could post picture on the web?
does anyone has wiring harness diagram?
what kind of fuel pump is good when i run GTi-R?
help me out plz
Yahnozha
04-28-2002, 05:02 AM
One main reason that a lot of people dont use GTi-R engines is the lack of components here in the states for those engines, your better off getting a BBDET. visit the SR20DEforums and youll find tons of information there and www.se-r.net
djlxsandiego
05-15-2002, 01:50 AM
I'm currently installing a GTi-R in my car, and will post my pictures when I'm done. I've talked with a lot of people, and they all say that the wiring is not difficult. I will post the details on my webpage when I'm done. There's a little grinding that needs to be done, but it's really easy. I heard that the GTi-R flywheel does not fit in the SE-R transmission, so you may have to modify the flywheel like I did. I know that some parts are different between the Pulsar GTi-R, and the other DE, DET motors, such as the Crank, and Rods and Rod Cap Bolts, but besides that, I think the rest is gravy... Make sure that you have a MAP sensor to use, and some ballast resistors for the injectors.
I have a source getting me some PDF files with the pinout for the N14 ECU and I have the G20 pinout for comparison, I will post again as soon as I get it... should be by this weekend.
I need some advice on building my intercooler piping... I need 2.25 piping, and am considering converting the endcaps on the stock intercooler so that I can front mount it... where can I get this off size?
Also, any suggestions for a downpipe?
