A/C leaking inder dash?
1990 Hilux surf
07-13-2005, 07:20 AM
My wife complained that liquid was dripping on her from under the dash. I thought heater core, but she said it was cold. I felt up under the dash, and felt a wetness.
Come to find out, she had the A/C on the the vent/floor setting. I am assuming it is the condensation building around the duct (it was plastic duct tube that was wet when I felt up underneath). I know it was not a heater core because it would be hot, and leaking under the passenger side. This was leaking under the driver's side. I also think it was condensation because it was night time.
Has anyone ever had this happen? I am not sure if it would be the same since my truck has the steering wheel on the right side (I am living on a humid island of Japan). I assume it is, but just backwards. Also, since there is a lot of humidity, it would be just condensation. Any opinions?
fourwd1
07-13-2005, 09:47 AM
There is a drain tube for the condensation, goes thru the floor/firewall and dumps the water under the vehicle. These tubes frequently block up and the result is what you have. Find and unclog the tube.
Brian R.
07-13-2005, 10:40 AM
Blow air up through the tube from underneath the truck.
