ECU Pins
Deathofadam
07-13-2005, 06:33 AM
Does anybody know if the pins to connect wires into the ecu are the same for all three connectors? I need to put a new wire into connector "A" and all I have is an extra connector "B" so I'm curious. I'd rather save a trip to the junkyard.
One more question, what rpm does vtec kick in on a stock B16?
Thanks!
FuLL BLown STD
07-13-2005, 10:05 AM
i believe stock vtec engagement is 5700.
what is it that ur installing a wire for.. just outta curiousity?
Deathofadam
07-13-2005, 03:12 PM
I bought a crx with a b16, and also a Field's vtec controller. He never wired the vtec from the controller to the ecu. Now I want to get rid of the check engine light.
EF You
07-16-2005, 05:40 PM
the pins on A plug are bigger than the pins on B and C plugs.
Deathofadam
07-17-2005, 04:18 PM
Thanks. I guess I'll be needing a trip to the junkyard. It's too bad that there is only one crx at the local junkyard. It's almost completely stripped already. (Thanks to me and my friends :)
