90 olds cutlass wont start
OldzCutlass90
07-10-2005, 01:18 PM
well i ran into a problem this car has been sitting for like 12 months and i got it back from the storage a couple weeks ago and it ran fine then a week later the alternator and belt and battery got all that put in filled up a can of gas and put it in the tank it started for like 5 minutes then it quit and cant get it started again i dont seem to hear the fuel pump going? how can i figure out if it is the fuel pump or not? if someone can help me that would be great
1990 supreme
07-10-2005, 11:19 PM
there is a fuel pump relay on the driver side strut tower and a fuse check the fuse then replace the relay you can also grab youre ac relay to check if thats the problem there is also a bleeder valve on the fuel rail with a cap on it its like a tire valve stem just use a screwdriver to push in the little valve in the middle if no fuel comes out then turn car on and do it still no fuel after all of above is done replace pump
OldzCutlass90
07-11-2005, 10:51 PM
well i replaced the fuel filter changed the fuel pump relay and the pump is going but still wont start and there is fuel coming out of the fuel rail now i am stumped checked all wires checked for spark and theres spark well i checked the 3 front plugs not the back too damn hard to get out anyone know what else could be causing this car not to start? cuzz its starting to get on my nerves damn 3.1's :mad:
1990 supreme
07-12-2005, 01:59 AM
is there fuel getting into the cylenders my supreme just did this and i replaced the computer it had fuel pressure at the rail but wasent injecting it and yeah damn 3.1's
OldzCutlass90
07-13-2005, 01:52 PM
well i changed the computer in the car bought one and same thing no go sounds like it doesnt even wanna try to start just turns and turns i put gas in a squrit bottle and squirted it in the throttle and still nothing so its got spark the computers good and its getting gas? now what should i check this is annoying me big time driving me up the wall if i had the money i would take it into the garage and get them to fix it but just lost my job so i need to do it all on my own :mad: if someone can point me to the right direction that would be awsome
OldzCutlass90
07-13-2005, 09:20 PM
ok i somehow got the car running for 5 minutes but if u press on the gas it cuts out? come on theres like 100's of people on this fourm someone should be able to help me
