Wheel Bearings
ArnzCardz
07-09-2005, 03:15 PM
I think I have a bearing hub going bad. Should I replace just the one or do both? Are aftermarket parts as good as OEM, since they aren't really? Thanks in advance,
rlith
07-10-2005, 07:04 AM
IF the other one isn't giving you issue, leave it.. I got my last one at advance and haven't had any probs with it. about 140 bux per side.
ArnzCardz
07-11-2005, 07:16 AM
i lifted up the front end and couldn't get any play in the wheels up & down. Is there something else I should be looking at? I have the noise when I am going straight and turning left. Goes away when I turn right... Thanks again in advance.
drdd
07-11-2005, 01:57 PM
When's the last time you greased your front end?
ArnzCardz
07-11-2005, 05:26 PM
Replaced right front wheel bearing hub, noise is gone. If one side goes, what are the chances of the other side going? Has anyone only had to replace one side? I have 99 4x4 with 73,000 miles. Thanks for all the info, and thanks in advance for anymore.
bwheeler
07-12-2005, 10:58 AM
I had to replace my right front wheel bearing at about 63,000 miles.
The left one was/is fine. That was about 2,000 miles ago. So far,
so good.
FWIW.
