B18b1 swap help
Jbyrd
07-08-2005, 02:38 PM
I am putting a b18b1 in my 91 hb. I am running it w/ obd0 pr4 ecu. Can I use my stock 1 wire O2 sensor on a DC sports header w/ o2 sensor located before the cat?
Scott82
07-08-2005, 09:57 PM
obd0 02 sensors are always before the cat as far as i have seen. but as far as the other sensors go if your running a obd0 ecu on an obd1 engine it may not run just right with some of the extra sensors, cause if i am right the obd1 B-series engines have a knock sensor, and some, not sure on B-series, have crank angle sensors also so just make sure you know all the details before you get it all started, but just something to have a heads up on
HONDA PAPI
07-08-2005, 11:46 PM
anybody wants to buy a b16a complete engine swap for 1350.00
b16a motor mounts
ecu may be a spoon ecu
engine
gsr tranny
msd ignition complete kit
aem fuel rails
