Radio
94century
07-06-2005, 10:29 PM
I have an 88 Suburban with the shaft radio still in it. It only works on the dirver side if I turn the volume knob just right and the bass slider control doesn't work anymore, it will not adjust the bass down it is all the way up. I was wondering if someone could recommend a replacement without spending a ton or is this a fairly easy fix. If not I will have to cut the dash and plastic bezel to install a regular radio, and I would like to avoid that if possible. My budget is around $150.
