b18b1 with which axles?
Jbyrd
07-06-2005, 09:05 PM
I am building a b18b1 for my 91 civic. I can't get advise that is repeatedly the same on which axles or axle/spindle applications to use. I don't want special made axles (hasport, Avid, etc.), I want to be able to buy over the counter axles. Some insight would be appreciated on what setup to use for reliability without sacrificing reliability and turning radius. I am also using a b16 tranny. positive feedback only please.
anthony90si
07-06-2005, 10:30 PM
a b series axle will fit in.(exept for the hf spindels i believe) the only this you have to do to the axles is remove the dust caps for clearence.other then that they bolt in with out any problems of steering.
Kunundrum
07-07-2005, 11:11 AM
axles depend on transmission... but with a standart 5speed LS tranny you use the 90-93 axles... unless you have a 4speed in the car originaly, then you need to change the hubs.
with these axels you MIGHT need to remove the dust cap on them I never did but some do.
In my B16 I use standard off the shelf 90-93 integra axles and have a 90-93 5spd half shaft.
Jbyrd
07-07-2005, 12:03 PM
I my car had a D-series 5 speed transmission. I have a 94 integra ls automatic half shaft. Can I use this half shaft? If so which axles? Should I have to replace my spindles? I am using an S1 b16 tranny.
Kunundrum
07-07-2005, 12:28 PM
if you plan on using a 5spd tranny that half shaft will not work. ditch it and go buy a 90-93 5spd one.
then use standard 90-93 Teg 5spd axles.
