a few problems
randolphsfinest
07-05-2005, 07:04 PM
I have a few problems with my 95 eclipse GS...
1) I'm burning quite a bit of oil and i'm not sure what's causing it, there's quite a bit of blue smoke coming out of my tailpipe and my low oil light comes on about a week or so after i top it off. I can feel a little blow-by when i put my finger in the oil filler hole, but not enough to feel any when i hold my hand above the hole, so i'm not sure if its my piston rings or not. I've already tested the fuel pressure regulator and i know thats not causing it.
2) I have a power steering fluid leak, but its nowhere near the power steering pump, its leaking somewhere on the drivers side near the firewall. i'm guessing its probably my rack & pinion because i can see fluid dripping from it, but i want to make sure it might not be something smaller before i go out and buy a new rack & pinion.
Any help would be GREATLY appreciated.
Thanks.
gthompson97
07-12-2005, 02:27 AM
1) your rings are shot. you can do a compression test to verify that
2) get a new rack & pinion.
randolphsfinest
07-12-2005, 12:25 PM
i should have updated this...
i did put in a new rack & pinion. that was the problem.
also, i did a compression test and all cylinders were around 70 psi. is this correct?
forextrader
07-12-2005, 02:57 PM
70 psi is way too low. Sounds like your rings are shot. Either that or your head is in need of guides, seals, etc.
gthompson97
07-13-2005, 12:19 AM
if you're getting 70 for compression AND burning oil, the rings are shot. you'll have to pull the motor and either do a quick ghetto ass rebuild and just do the rings or a complete re-build. or you can just buy a different motor too.
