Del sol w H22 is it possible?
willsol
07-05-2005, 03:14 PM
Hey,
Im new to this sight and pretty new to hondas, this is my second and I want to put an H22 into a 93 Del sol. Im in the Air Force and currently in England so I dont have access to everything stateside, but I can make do over here. The reason I want to do this swap is because I can get ahold of an H22 cheaper than any b-series, it seems to be a rare swap, I like the torque in the H22, I want to stay NA, and to top it all off I have a "friend" who says it can't be done and I like to prove people wrong.
The main thing he sights is weight and the fact of the shift cable linkage needing a hole to be cut in a very precise place that might hit the main wiring harness for the car. Not sure if hes right but I would like as much help as possible. Thanks for checkin the thread.
-Will
BLU CIVIC
07-05-2005, 03:18 PM
if you can put a legend v6 into a 5th gen...anything is possible
i think the del sol engine bay is the same as the regular civics....so it should be easy to put in...but but everything else may be a lil complicated
BLU CIVIC
07-05-2005, 03:34 PM
http://www.hasport.com/92-95_Civic_H-series.htm
http://www.tunedbylorange.com/delsol13.JPG
http://www.tunedbylorange.com/h22delsol.html
btw...they don't like it when u post the same question in mutiple threads
willsol
07-05-2005, 03:43 PM
Ok, lesson learned on that one just trying to get to the most people I can and thanks for your reply and the info...hopefully someone who has done a complete swap will see this, I hope...
BLU CIVIC
07-05-2005, 03:48 PM
i think you'll find a lot if you search www.honda-tech.com
http://www.honda-tech.com/zerosearch
type in "h22 del sol" and select "archived content"
ImSoYesterday
07-05-2005, 10:15 PM
I have seen a $g63 in a del Sol. The fact is, if you have enough money, you can do it. I have also seen a 350 in a Cavalier... Money is possibility.
CivicSpoon
07-05-2005, 11:17 PM
Jeeze, it's not that bad (legend or 4G63 engine). Should be the exact same as the h22a 5th gen swap. I'm not really sure on the shiftlinkage length though (isn't the del sol's shorter?).
alphalanos
07-05-2005, 11:22 PM
wow i bet that H22 Del Sol is quickkkkk.
AudioGuy93DelSol
07-06-2005, 11:12 AM
THe H22 has cable shift linkage, not like the bars B and D series have. Oh and might i suggest this
http://www.automotiveforums.com/vbulletin/showthread.php?t=332296
CivicSpoon
07-06-2005, 12:48 PM
I just ment that because the del sol linkage might be shorter, the h22a linkage might be too long. I knew when I posted that, that what I said would be misunderstood (I should have known better).
