Painting lenses
240SXSlideStar
07-05-2005, 10:31 AM
Well I looked in the painting section of the FAQ, but couldn't really find an answer, so here's my question, should I put the lense paint on the inside or outside of the lense? I have Model Master Signal Amber Metallic, it's all that my local hoby shop had.
white97ex
07-05-2005, 12:14 PM
put it on the inside.
99civichic
07-05-2005, 12:30 PM
Inside works best. Also, try using sharpies for red lenses. I got that tip off this site and used it on my Ferrarri and it came out great.
Another way is to paint the bucket instead of the lens; try to find a pic of the real car-if the lens is actually colored, then paint the lens. If the lens is clear with, say, an amber bulb (like on my 1:1 Civic) then paint part of the bucket.
bhop73
07-05-2005, 01:03 PM
Since you mention amber, I assume you mean the turn signals, which can be done the same as the following brake lights, but I use Tamiya clear red and paint the whole thing. Then paint the back of it silver. At least that's what I did here:
http://bhop73.com/models/eclipse/backlights.jpg
240SXSlideStar
07-05-2005, 02:42 PM
Alrighty, well I'm ganna do like bhop did since it came out pretty nice.
RallyRaider
07-05-2005, 07:16 PM
Yeah inside is best. But sometimes, depending on the way the kit is engineered, you have to do it on the outside and it works fine too.
blubaja
07-05-2005, 08:27 PM
Silver or bare metal foil base. Then paint the turn signal amber or red as needed. Sharpies work too. A black sharpie along the outter edges of a lens adds some realism also.
Frank X.
