code 27 showing
teemsta
07-01-2005, 04:21 PM
so i did the code check andit came up 12 27 27. a chart shows "fault in injector driver circuit" for 27. does anyone know how to resolve problem? my 94 jgcl 5.2 is stuttering on the roadway but check engine light does NOT show at all.
qtip101
09-03-2006, 11:59 PM
having the same problems with 94 stuttering on highway at 50-65 miles an hour and do not know what the problems may be . it has new wires, dis.cap
new plugs, new ign. coil, new crank shaft sensor .
someone , anyone , please help .
chris
Caribbean ZJ
09-04-2006, 12:19 PM
i had a code 27 a couple yrs back. it was the injector wires. For some reason they became very hot and the plastic wire housing began melting the wires together. You will have to inspect the wires along the rail for any melted plastic. separate if necessary and 're-house' each individual wire. i used electrical tape. never had the prob since. Then again can just be a cut wire. Atart looking at the wires in the black 'box along the fuel rail
