starter problems
j12od
06-30-2005, 07:03 PM
My car is actin dead. The battery keeps gettin drained but I dont know what is draining it. I got a new alternator, i replaced the battery cables, unplugged my system, and got a new starter. i need help!!!!
fobearbc
07-01-2005, 01:07 PM
check the light in your glove compartmant and your trunk and hood, see if they stay on when the car is off and the doors are closed i had the glove compartment light drain my battery for 6 months before i saw the light on one night... could be an easy fix
j12od
07-02-2005, 04:30 AM
are there any possible problems with the starter affiliated wit the battery?
fobearbc
07-03-2005, 02:14 PM
yeah, but if the starter was the problem, it would have been fixed when you changed it...more than lickly its something that seems completly un related...
j12od
07-07-2005, 02:13 PM
it works when i push start it and when i jump start it too
xblastxb16
07-09-2005, 02:32 AM
even though you got a new alternator you may have a bad voltage regulator and its not allowing your battery to charge correctly.sign to look for are when your driving an your car only shuts off when you stop or your int. lights flucuate good luck hope i helped
