power window motor replacement
prettybird
06-30-2005, 05:12 PM
I am trying to replace my window lift motor. But don't see all the parts they are talking about. I would love any info on how to's. Has anyone had problems with their windows?
DMS825
07-02-2005, 11:26 AM
Not sure what year you have, but on 94-95 you pop the cover off the door light and remove the screw that's in there. Then pop the piece out that holds the lock and window switches. Remove the ground screw underneath that and lift the door panel off. Then remove the speaker. There are three bolts that hold the window motor in. Remove those, and reach in through the speaker hole and remove and unplug the window motor. Reassemble in reverse order. Once you've done it a few times, it gets to be pretty easy.
prettybird
07-03-2005, 02:21 PM
Thanks for the idea of going thru the speaker I'll try it right now. Though my bird is an 89 everything sounds like it's in the same places.
